I am finally ready to install my new brake Master Cylinder on my Rx7, but wanted to know the best way to go about bleeding the system.
Normally, I'd just bench bleed the MC, install, and then bleed all four calipers. But I have brand new calipers on all four corners, brand new lines, and a brand new MC. There's no fluid left anywhere in the system. Op
My thinking is that there are two courses of action:
1. Bleed the current MC and lines as installed, then bench bleed the new cylinder and swap them.
2. Bench bleed the new cylinder, install, and then bleed the lines.
Clearly option two is preferable, but my concern is that after installing the MC and going to bleed the lines, the freshly bled cylinder may drain into the empty lines leaving me with an un-bled MC.
If a Master Cylinder is bench bled and then installed on an empty system, will it drain and require being removed and re-bled on the bench? Or will I be able to fill as normal by keeping the reservoir filled while pumping the pedal until the fluid leaves the line on each corner without bubbles?
Thanks, Chris
Thanks, Chris
