hi all,
i have a 2003 cobra with the t-56 6speed and it is hard to shift. i have 7800 miles with the factory fill and i was thinking of trying mobil1 atf because i get readily get it down the street at autozone. redline says to use D4ATF but it causes the carbon fiber synchronizer seals to swell and shift even harder. i used redline D4ATF in a ,99 GT with a T-5 from 40,000 to 80,000 miles and i had a input shaft bearing noise develop around 60,000. tremec recommends dexronIII without any gear ratings in their T-5 and T-56. one tremec rep said to use mobil1 at svtperformance.com but another rep from their website said ford had stiff shifting problems with mobil1 in 2001. (ford didn't use the t-56 until 2003 so who do i believe!)i also put redline 75w90 with built-in friction modifier for the limited slip at 60,000 and no metal shavings when i drained the factory fill. at 82,000 i had a noisy rearend full of metal shavings and i ended up ovehauling and replacing every bearing so i'll never use redline again. i was thinking about royal purple. any knowledgeable responses are welcome. TIA
