Originally Posted By: 92saturnsl2
I took the plunge, went to HD and bought the PAS-225, and sadly it's getting returned tomorrow.
The unit right from the get-go was a no-start, dead as can be. I'm very careful with new equipment to read the manual, familiarize myself with all the functions / features / safety stuff, and I did just that. As a break-in precaution, before I even went to start it, I took fuel out of the equation and purchased Tru-fuel 50:1 2-stroke, ultra expensive "engineered fuel" that is both JASO FD and ISO EGD certified, which the manual suggests. Even when I mix my own, I only use 2-stroke oil that meets FD & EGD, instead of the universal watercraft stuff (TC3?) that is common on store shelves.
The bugger wouldn't even sputter. I'd like to think I know every trick in the book for getting stubborn 2-strokes to start, as I've worked on more than my fair share, either my own or friends' cheap $100 units. I'm usually successful at it. Pulled plug, checked for flooding, pull rope with plug out to rid fuel (it wasn't flooded), repeat the manual steps a half dozen times, no go. I finally got frustrated went to eat dinner, and came out with a long-stem lighter and warmed up the plug tip and put the flame into the spark plug hole to attempt to heat the chamber. Afterwards, TA-DA a running trimmer.
Once it was running, my overall impression was that it's a solid unit. Fairly vibration free, heavy enough to feel like it's built right, but light enough not to wear you out after a half hour or more of trimming. Just good build quality with great throttle response (once warmed up). I liked it. However, it still bogs down in the overgrowth I'm cutting. That alone wouldn't be a deal breaker, as I dealt with it on my last trimmer, the aforementioned 4-stroke Propane power unit I had (which was no dinosaur, it was state of the art in 2011!) The real killer is that it won't accept my cultivator attachment, which was the whole reason for choosing the 21cc Echo over the 27cc Stihl which doesn't accept attachments. I falsely assumed the attachments were interchangeable, after all my old trimmer was a Lehr brand with a Ryobi cultivator attachment.
Error on my part, but if I'm going to spend $249 on a trimmer that will only be that, I'll spend an extra $40 for one with more power that will cut down this stuff I have without bogging, and then buy a cheap $150 Ryobi power unit to run my cultivator attachment. I think Echo did themselves a disservice by making their attachment proprietary, but it is what it is. Echo has a trimmer with a larger engine (SRM-266), that is emissions rated for 300 hours, as opposed to the SRM-225's 50 hours. That tells me it's a commercial unit, and with a larger engine, it might be what I'm after. If Home Depot balks at giving me a refund, I might exchange for that one, as there wasn't a lot I didn't like about the 225 model, except a bit underpowered and lack of attachment compatibility.
They will take it back, I recommend a Stihl even at a higher price as any decent dealer is going to give it to you assembled, fueled and have it running before you even pay for it. That practice plus products that last have sold me on them.
With that said Echo is quality stuff and I'm surprised you had an issue getting it to run.
