Best specialized AC condenser cleaner for an auto?
Without getting too specific, for my late-summer road trips... I'll probably have the AC on. Usually I can get it running so well that even having the fan on setting "1," sometimes 2 or 3 if it is a blazing hot day, will work. So I want to clean my condenser, huge thing in front of radiator.
I've hit it with degreasers which I do not know if it has done harm, same with old fashioned spraying with water. No visible debris or bugs.
Is there a best specialized cleaner spray you use or method to keep it as clean as possible? I welcome all answers.
And obviously, I cannot remove it..
Home Depot has the stuff for household ACs, with the foaming agent. I’ve watched before and after pressures on a Freon gauge set and even if the foam drips off looking mostly clean, it made a difference in the pressures.
If you have no visible debris present, I would not use a cleaner. If it needs degreasing, chances are there is a slow leak present where the oily grease is.
