Originally Posted By: superior_power
For all you naysayers, let it be known I am not partial to any brand of plug. I seldom use anything other than Bosch, NGK, and Champion. It will totally depend what I am working on.
Honda engines get NGK,
most Kohler and B&S get Champions. For you guys who claim Champions are no good, I have installed several hundred champions and have yet to have a single problem.....
Most 2 cycle engines get NGK or Bosch. Check manufacturers manual for brand to use.
Spark plugs may run fine for multiple seasons, but keep in mind that you may be placing your ignition system under greater stress and setting it up for failure. With this said, I find spark plugs much cheaper to buy than ignition systems.
It is however, very important to install the correct spark plug or at least the correct heat range.
Excellent post. I see "NGK Gold Standard" and ask why? Good plug,Not arguing that, but is there any proof on the dyno or lab? I see no difference between manufacturers on my test tachometers when I use the appropriate plug for the application. Material and electrode style don't seem to matter to initial performance as well, but people will swear it runs "smoother". I can put an autolite 254, Champion CJ7 or a NGK BMP7 in a 2 cycle and dare anyone to tell the difference. I tweek a carb screw 1/4 turn and you will notice a difference. If it fouls, it was the darn plugs fault.
I buy fine wire and better metal for to save on iginiton componenets. I buy heat range based on engine performance. I use Autolite, Bosch, Champion,Denso and NGK, but I am just not sure brand is all that. Does this go to perception as much as reality, similar to (dare I say) motor oil and small engines
.....but at least we have UOA and chemistry to back up our motor oil discussions
