- Joined
- May 10, 2024
- Messages
- 6
I have a 1987 Chevrolet Silverado R10 (700 R4, 10-Bolt Rear) that has a leaky rear differential. I have all that I need to replace the gasket, but I am going to be putting new fluid in, and wanted to see what would be best. Background information: the rear end was rebuilt back on 10/18/2016, and it has not needed to be serviced until now. The owner's manual states that SAE-80W-90 GL-5 is the reccomended fluid and lubricant. To my knowledge, SAE-80W-90 GL-5 is what was used after the rebuild, and is still what is in the rear differential. While I do think that the rear end was rebuilt well, it has always (since the rebuild) had a slight howl at speed.
My question is two-fold. Is there a "best" lubricant that would be a higher quility for the long-term? I have seen discussions on this forum regarding Redline products, and discussing their superiority. I have also seen posts that caution against using any lubricants with a friction modifier or posi additives, per a GM service bulitin. I defintely don't want to make a mistake and get something that includes those, which also pushes me toward something like Redline. The other aspect to my question is surrounding the noise, and if an increase in weight would result in the noise being cut down at all, which I have also read on a few forums.
Thanks in advance for any advice that you have!
