I can not find the reference at this time but a Noack rating of 11.0 is the max that should be used in a GM, and probably all, DI engines. 10W30 will tend to have lower Noack numbers then 5W30. Typically a slight difference.
To the question, “what the NOACK Volatility means and why it's important”. In a non DI engine the gas passing over the intake valves helps keep them clean and aids in “washing off” vaporized oil. In a DI engine fuel does not pass over the intake valves and thus vaporized oil will deposit on the valves. There is a pic somewhere on BITOG of a VW / Audi DI head after 7X,ooo miles and the valves are caked with deposits. If not corrected this will lead to messing up the valve seats as well as the valves.
