IQraceworks
Thread starter
- Joined
- Feb 15, 2022
- Messages
- 8
Kind of a side question.....but does running a diesel rated 5w-40 oil like T6 have any advantages vs. a car oil like M1 5w-40?
In most cases it's going to have a higher HTHS and be more resistant to shear. At least as long as you are talking about mainstream products.Kind of a side question.....but does running a diesel rated 5w-40 oil like T6 have any advantages vs. a car oil like M1 5w-40?
Can you please give me some details on why the M1 Euro 5w-40 is better than the T6 5w-40 ? Just trying to learn something....
Thanks for the info! I always thought the diesel oils were better because they were "heavy duty". I guess not!Higher calcium-based detergent content and higher starting TBN that will be beneficial for water and fuel dilution from E85. It also contains a small amount of AN which helps with friction reduction and high temperature stability, as well as more boron-based EP.
KV and HTHS are higher in HDEO, soThanks for the info! I always thought the diesel oils were better because they were "heavy duty". I guess not!
Which Pennzoil Platinum Ultra meets even the minimum requirements for a stock BMW N54?If looking for the generic off the shelf stuff then Pennzoil Ultra has the super low noack ~5% differentiating factor due to the stout GTL base.
This in theory should excel in deposit control which is important with turbocharged engines.
Perhaps your advice would be relevant if the car was factory stock.If I may say, you should change oil more often (with the one that meets your car specs) rather than looking for ideal oil
So what your are saying that if given the choice of M1 0w-40 vs. T6 5w-40......the T6 is still the better choice...right?Wanted to correct my statement. I misread the question as being about the common M1 FS 0W-40 vs T6 5W-40.
I'd personally go M1So what your are saying that if given the choice of M1 0w-40 vs. T6 5w-40......the T6 is still the better choice...right?
The T6 will have a higher HTHS and will have less permanent shear so the HTHS should hold up better in an application with high load, high rpm and high heat (Like a hig boost car in 40 minute sessions at Road Atlanta). The M1 0W-40 might be my preference for the same car in street use with a longer.drain interval, lower average loading and lower oil temps.So what your are saying that if given the choice of M1 0w-40 vs. T6 5w-40......the T6 is still the better choice...right?
I can't say on E85. On Methonal.we ran Valvoline VR1 20W-50 (VV211) and changed after every race.Note the use of E85 as that's an important factor here that leans more to M1 FS 0W-40 in both scenarios you mentioned.
Film thickness, not film strength.In this case, I'd concentrate on shear stability, actual viscosity and HTHS. The benefits of additional additives don't mean much if the rod bearings take a pounding due to inadequate film strength. My suggestion to avoid 0W anything stands. VII's are not ideal for highly stressed applications.
