thanks DannoAssuming oil cap says 5W-30, as mentioned, any oil meeting the Ford spec and at most 5k changes. Ignore the OLM unless it tells you to change it sooner than 5k.
A list can be found here.
In order of my preference.
1. Castrol Edge EP (look further down the page)
2. Mobil 1 Advanced
3. Valvoline Advanced
https://www.bronco6g.com/forum/thre...at-meets-ford-spec-wss-m2c961-a1.82783/page-2
Bit of a waste, but if that's your mantra, then there is no "best" because any syn changed at such short intervals will not manifest into any distinguishable difference for your engine. Might as well buy the least expensive oil that meets the spec; anything more is just doubling down on waste.I always change @ 3000 miles with synthetic
If youāre going to change it that often then go with the absolute cheapest synthetic you can find (Kirkland, Supertech,etc)I always change @ 3000 miles with synthetic
thanks gents![]()
3K miles? No need for Synthetic. You can do a lot worse than this.I always change @ 3000 miles with synthetic
thanks gents![]()
If you change it that often, it doesn't really matter what you use as long as it's at least a 5w-30 grade and meets API SP specs. WSS-M2C961-A1 aligns with API SP, BTW.I always change @ 3000 miles with synthetic
thanks gents![]()
240,000 on my 21 escape. I use amsoil xl 5w30thought I'd ask the experts.....ordered a 25' Bronco with the 2.7L V6
not interested in HP or speed, I want longevity.
which full synthetic and weight ?
sincerely and THANKS
Except Motorcraft Synthetic Blend...it was an xW-20 in 1,000 miles in my 2.7L. Imagine had I left it until the iOLM said to change it.There is no ābestā oil. Just use one that meets the spec and change it regularly
