Hey guys, i have a 71 pinto 2.0 and a 71 buick Riviera gs, and i was wondering what the best oil for these old engines are? valvoline vr1, diesel oil, mobil one, etc? and what weight as i heard modern synthetic doesnt have the same weight as older weight so would 15w40, 15w50, 10w30, 10w40, etc?
Both will be fine on Castrol 0w40, it has enough zinc to prevent tappet wear and higher viscosity these old timers need. 15w40 in the 2.0 will noticable bog it down, it only has 99 HP to begin with.
The Buick is one of my favorite cars of all time, I have owned many, rebuilt them and built them from scratch, I stopped owning them after the 73 model.
The small blocks, 430 and 455 has some oiling issues that really need to be addressed if you want to keep this car long term (of course you do, LOL).
These are notorious for low oil pressure that eventually wipes the bearings out and put a tremendous load on the cam. The cause is the front cover which acts as the oil pump housing, water pump mounting, etc.
Back in the day we used a gear mod, extension block and sleeve to get more oil pressure but today there is a much better alternative that will give good pressure even at idle. If this mod has not been done I strongly recommend doing it, the engine does not have to come out and can be done easily in one day even taking time for lunch, and coffee breaks. This is the best thing you can do for that engine.
I would also use a small amount of zinc additive to bring the zinc to about 1200-1400 ppm, these had smallish cam lobes with a higher ratio rocker arm on some engines (shaft mounted), lots of strain on the cam lobe.
PM me if I can help you with this engine or car.
Edit: this engine uses rope seals for the main and original front cover, the Castrol 0w40 does not cause them to leak or worsen an existing one.
