Originally Posted By: Joseph_S37
My wife drives an escape with the same engine, also short tripped, and I've personally decided to bump the grade up to 5w30, maybe even 5w-40 soon. The reason behind this is the fuel dilution that I've noticed. The dipstick reeks of fuel, and the oil level actually ends up rising by the end of the OCI. Not sure if all the 1.6 ecos exhibit the same flaws, or just ours, but from what I've seen, 5w-20 will be watery with fuel in no time...
Anyways, I'd love to hear other comments on the engine. The current fill in ours is Mobil 1 5w30.
I missed your post before recommending the same thing myself: Use Castrol Edge 0w40 and watch the visc drop over a full oil change interval. That oil has the most high performance specs of anything I've seen, and you can get it at Walmart for cheap. ....... Running rich with the turbo and getting blowby past the rings must be whats doing the dilution, I'd guess.
