Best oil Catch Can???
State
I know there are lots to choose from for oil catch cans... but, I'd like to rig up one with a valve on the bottom where I can reach in an manually push a lever (don't want a twist setup to have to unscrew, but some sort of valve that has a lever that can be pushed to open it) to drain the catch can that also has space to clamp a hose on to.
That way, I can run a hose from the catch can down towards the ground so I can push the lever and drain the catch can into a pan below the truck (I'm doing this on a full size Chevy truck with a 5.3L engine)
Anybody seen a setup like this for sale?
(I can provide the drainage hose)
Ideally you want it draining back into the oil pan not a cup or a pan on the ground. There are a few Euro cars that use this system, you may be able to fab something up using a similar design.
This is the latest generation...
[Linked Image]
This is an old system but it still worked well, VW used a similar setup..
[Linked Image]
[Linked Image]
The hose you see hanging down from the container under the hoses #16 goes into the oil pan.
If smog laws do not prevent you from modifying emissions control systems, then look for a moroso exhaust extractor from jegs - theyre maintenance free, fit and forget, keeps your intake tract SIGNIFICANTLY cleaner than any other permutation of the catch can/pcv, and improves horsepower.
More power and less maintenance ...
I have a Moroso can on my 5.3 Suburban. Works perfectly. It has a 90 degree valve on the bottom for draining.
[Linked Image]
[Linked Image]
[Linked Image]
Personal,y I wouldn't want the contents of a can going back into my oil pan, have you seen some of the stuff you catch in the can? A lot of water mixed with oil...don't want it going back into that sump. Heck, I don't think half of it could flow through a tube or line to get to the sump. This stuff is thick and nasty. Just cleaning outhe can takes effort when that condensation mixes with that oil.
How about a link?
Does this use exhaust flow to create a scavenge vacuum keeping all vapors out of the intake completely? Backfire protected
The can I made wasn't sophisticated at all, but worked good. The emphasis was put on a very long inlet hose to provide maximum condensation of fume and vapor. The can was placed in the coolest place I could find in the engine bay to further cool and help things become liquid. The downside for me was the drain was too small, so I had to flush the sludge out when draining.
[Linked Image]
[Linked Image]
[Linked Image]
when it going back in the pan continuously its not an issue, when the oil gets hot the contaminants burn off quickly. Its not like it waits till there is a ounce or two then dumps it.
The vast majority of aftermarket "catch cans" are worthless garbage anyway and not something I would waste 10c or 10 seconds labor on.
last year i wanted a catch can. i took it to a good mech. after 20 min he came back and said that my 2016 Frontier had a good one built in from the factory.
