Best Oil 2005 Ford Taurus
Almost any oil will work well in this engine for 5k. However you should make sure you change your ATF, watch for coolant leak at water pump cover / coolant expansion tank, keep an eye on the cam synchronizer sensor, etc.
It should last a long time if you keep it maintained well.
