How should I go about changing the front diff fluid on the Mounty if it only has a fill plug? Not sure why Ford chose to do that seeing as how the transfer case and rear end both have drain and fill plugs. I read that the bottom most bolt can be drilled as it would pass through the housing? Not sure how that would even work.
