Best Impact Gun for removing rusted bolts
This thing is great. I didn't change any fittings (used compressor with quick disconnects) and it had no problem removing an axle nut, all lugnuts, brake caliper bracket bolts and wheel bearing bolts. Highly recommend.
The tool fitting opening where it plugs into the hose connector if high flow will be about 7.2 mm. The size of the hole difference will be obvious when you compare them to normal industrial or balloon fittings.
Two High Flows and a standard.
Nitrocat 1200 1/2" drive 900 ft pounds break-away. Puts Ingersoll Rand to shame in our die Maintenance shop; which is a torture testing ground for air impacts.
