In your opinion, what is the best High Mileage Oil? I'm currently using Castrol 10W40 in a 95 22RE with 135,000 miles. It has almost eliminated the oil consumption in my truck. I see alot of you like the Pennzoil. Any particular reason? Rando
Their data sheet is wrong though, I found through my used oil analysis that Maxlife 10w30 has a viscosity of 11.5cst at 100c, not 10.5cst as their data sheet suggests.quote:
Originally posted by TallPaul:
From the tech data sheets I have seen on several high mileage oils, Valvoline's Maxlife is not as thick as the others and actually is a tad thinner than regular Valvoline.
Is it possible that it thickened some in use? Wonder what a VOA would show. The high mileage oil tech sheets for Citgo, Chevron/Havoline (apparently same High Mileage oils), and Quaker State list 100C viscosity at 11.8, 12, and 1.2 respectively. If the Maxlife is 11.5 then it is not that much different for the 10w30s.quote:
Good point! 40C though not winter temps would indicate which oil is thicker coming off the cold end. Unfortunately, Valvoline does not give the 40C on Maxlife. I don't mind the thicker base oil as long as it works in winter. Maxlife that I use (10w30 and 10w40) I believe have -36C pour points--not bad at all. Perhaps the 10w40 Maxlife is more like a 15w40. But a thicker base oil in a 10w40 is good in so far as minimizing the number of VI improvers added.quote:
Originally posted by Motorbike:
Paul,
When comparing these high mileage oils look at the vi @ 40c . You'll see a higher vi across the board than regular oils with decreased cold weather performance. It's not all about a higher vi @ 100c .
Less vi improvers/pour point depressants most likely along with heavier basestocks blended is another possibility.
I don't think it thickened in use for one big reason. My first UOA on this oil was with around 2300 miles on it and it showed a viscosity of 11.4 cst. The second one was with 3300 miles on it and it showed 11.5. So if the oil was indeed thickening during the interval, then the second UOA would've shown a thicker viscosity due to the higher mileage. My LT1 engine also appears to be very gentle on the oil in terms of viscosity, it neither thins nor thickens any oil I put into it (I probably should've tried RP in it just to see if it thinned out!)quote:
Don't feel bad, I get few replies too.quote:
I just bumped this analysis to the top that was posted awhile back in the UAO section . Pretty good I would say even though it received few replies for going right at 10k miles !
Castrol Dino.............the 10k mile oil![]()
!0/30 Castrol GTX High Mileage
The main reason you get few replies on your used oil analysis is because you refuse to tell us what type of oil you're using. What are people supposed to do with the info you're providing them if they don't know how they can duplicate your results?quote:
You have a pretty solid case. I will not post that it is thinner any more unless it changes and a VOA or UOA shows it to be thinner. Thanks, Paulquote:
