What gives you the idea it needs more grease? This type of LFL joint needs very little grease to live more than 20 years, adding grease through the boot on top of the ball does not really do much for it. If the boot gets damaged its time to replace otherwise leave them alone, the boots always appear empty on these, it is normal.I took out my bmw control arms to replace the bushings, and would like to add some grease to the ball joints. They are the sealed type but I can easily insert a grease needle next to the tapered shaft.
I'm thinking marine grease since it's less likely to leach out and be affected by water?
http://www.dulub.com.tw/brochure_01-to-64/pdf_English/57_eng-HighPerformanceBallJoint.pdf
https://www.machinerylubrication.com/Read/31398/klüber-automotive-greases
