- Joined
- Nov 29, 2009
- Messages
- 10,258
I bought a Honda eg6500 watt generator. 6500 watts is the maximum output and 5500 is the rated watts. I generally have been running it at around 50 percent load since new. It now has 4hrs on it. Should I break it in with a heavier load? I've altered the loads a little bit. I have a 1400 watt worklight so I'll alternate the load a little bit between 1400 and 3500 or so watts. I have some 1500 watt space heaters I run also. I just want to make sure it has a good enough load on it to seat the rings. I put the worklight on and it barely even boggs down. So far it hasn't burned any oil. Also what is the least amount of load you want to run on a generator? I've heard it's bad to let them just run with hardly any load. Also it says to change the oil after the first 20hrs but I'm going to change it a couple times before then.
