100% - it's the best I have ever used. I know the guy who developed CorrosionX, he has an account here and was the head of lubricants development for one of the majors. It's the real deal.CorrosionX.
I keep a bottle at my gun bench, and some by my tool boxes for wiping down tools.
https://www.corrosionx.com/
CorrosionX is a darn good product, it is a liquid, thin film. They also make a product called MaxWax, thicker when applied, dries to something like a waxy coating and is absolutely spectacular with it's ability to seal up metal parts in a more harsh environment. Better than Boeshield or LPS3 by an order of magnitude. It rivals AV30 or other extremely high end coatings. Waxy and tough, without being oily or hard. Works incredibly well on uncoated parts such as a Ford driveshaft yoke, and attracts no dirt.CorrosionX.
BBFF (boat’s best friend forever)100% - it's the best I have ever used. I know the guy who developed CorrosionX, he has an account here and was the head of lubricants development for one of the majors. It's the real deal.
Yes. Always.Always G96.
CorrosionX.
So are you using this to wipe down the outside of your guns? I'm using HPL gun oil. I am thinking this is for long guns like shotguns , rifles ?CorrosionX is a darn good product, it is a liquid, thin film. They also make a product called MaxWax, thicker when applied, dries to something like a waxy coating and is absolutely spectacular with it's ability to seal up metal parts in a more harsh environment. Better than Boeshield or LPS3 by an order of magnitude. It rivals AV30 or other extremely high end coatings. Waxy and tough, without being oily or hard. Works incredibly well on uncoated parts such as a Ford driveshaft yoke, and attracts no dirt.
Of note, the Aviation CorrosionX (blue can) and the standard (red can) are the same product, and the company says so. The blue can is Mil Spec.
CorrosionX is also a spectacular lubricant due to its polar bonding technology. It is very well known in the electric motor/RC and hobby fields as the best motor lube. This also makes it a perfect choice for firearms. It is far less likely to attract dust/dirt than most oils. It is roughly a 10 viscosity oil, at 47 cSt @ 40°C
Blue and Red can = Same product
Yellow can = Thicker, dries tough
I just use the CLP for tools - removes any bits of grease or dirt, leaves a protective film. It’s a fine line between optimizing the product application, and keeping the inventory of products manageableSo are you using this to wipe down the outside of your guns? I'm using HPL gun oil. I am thinking this is for long guns like shotguns , rifles ?
Astro, which can are you using for tools? Whats the application for the yellow can ?
Thanks!
Typically engine oil is average to poor in external firearm rust protection - however it makes a great lube .Leftover clean engine oil, got quite a bit of it. I'm not stuck on only it though, just haven't gotten anything else.
Thinking an NMMA approved motor oil would be better at rust prevention than your average street oil etc …Typically engine oil is average to poor in external firearm rust protection - however it makes a great lube .
