That will work just fine.whats the best lube to use for drum brakes? specifically where the shoe meets the backing plate.
I was gonna try permatex ceramic extreme lube, any one ever used it?
not all anti-seize dries I use a bentonite clay based anti seize and it doesn't dry.Well sure - then we can say bacon grease is also lubricant. Also, plain old spit would lower torque values.
Anti seize [as a lubricant] is a poor choice for moving parts.
I used it on countless things, and have a good handle on what it is suitable for. It gets dry and allows metal contact. It is helpful for movement for a very short term only.
Grease has oil suspended in it, and continues to flow and lube things.
I was thinking I was gonna need something with alot of solid EP additives ???
