Best Dexos2 oil
Originally Posted By: yannis
Read what Lubrizol found out in pages 19-20 when a non specified older generation lubricant is used in new direct injection, gas or diesel engines:
Yannis,
Since certain time I don't have a trust in all these promotions. What cars, what oils, what conditions ? May be, if we look closer, we will find out that given engine design and its parts fabrication leave much to be desired and comparison is just a juggle ? If to face up the real things all last trends look like a plot of car and oil manufacturers under the cover of a pressure from the side of environmentalists. I would not be surprised if the latters are in the game too. The progress is finished with Euro3. Euro3 was justified. But then car manufacturers became to live in their own world: they invent for themselves some artificial obstacles and objectives and then try to overcome the formers and reach the latters for the account of us, consumers. And oil manufacturers are happy to follow car manufacturers. They ask themelves why not if it brings money !
You gave a link to VOA of Motul X-clean in Russian. This one of VOAs ordered by the same technical center which I mentionned in my post about Japanese OEM 0ils. VOAs of Motul oils are in Part 1. I put some data into the table, so let's have a look:
Code:
X-cess X-clean LL-04
Calcium 2725 1909 1896
Magnesium 10 6 6
Boron 75 71 70
Zinc 1137 998 996
Phosphorus 980 813 811
Sulfur 0.35 0.21 0.21
I don't believe that 14% higher Zinc and 20% higher Phosphorus may really damange something. At least in properly designed and manufactured engine with a small oil burning. Well, if you take some VW engines that burn 1 liter per 1000 km, then this is another story. But let they make normal engines instead of some Lego, then they will not need low ash oils. BTW, a.m. technical center has nearly similar view based on years of its experience. Regarding diesels and ERG pipe blockage, I heard one real professional from Germany and he recommended to block the pipe just from the beginning. No harm at all - your engine will be only thankful for this. But this works only with diesels. As for DPF, this is really a disaster: for the moment it is just a very big everyday headache for end-users, but humanity has not yet understood all consequenses for the health.
Xevus,
Actually there is no much historical data to judge something and our points of view would be very subjective. Unfortunately nowadays manufacturers hide composition of oils in their MSDSs, and obviously there is something to hide, so the only way for a first approach is PDSs and own trust in this or that manufacturer provided price does not matter. Properties of oils from your list are more or less similar, just tiny differences, especially it concerns Liqui Moly, both Motuls and Shell, so conceptually all would have to behave in the same way. Personally I would prefer Fuchs and Shell. The former because it's the only one who indicates NOACK in its PDS and it's quite low (7.7% - I believe it will be the lowest within the list). Besides, its PP is also slighly better than -36C common for this group of oils. As for Shell, I mentioned it because of own 2.5 years experience in Mazda6. It contains two HC oils (no PAO or Esters), but I had nothing to complaint. It may be not relevant to a diesel, but neverthess.
Just a couple comments regarding Motul, as I pointed out PDSs of both grades are very similar and it is very difficult to say what's really better. MSDSs show:
X-clean 5w30: DISTILLATES (PETROLEUM), HYDROTREATED HEAVY PARAFFINIC * 25
Dexos2 5w30: DISTILLATES (PETROLEUM), HYDROTREATED HEAVY PARAFFINIC * 50
At the first gaze X-clean looks preferable because it has less hydrocracked oil. However, we don't know what is other 50-75% of base stock. Manies may think other part is PAO. May be, but X-clean VOA showed NOACK = 9.43% (and FP = 214C vs. 230C in PDS)and it means that HC content lies to higher end of spec. To my view before defining whether a remained part is "better" or "worse" it will be difficult to judge which of two oils has higher quality base oils. In reality, given nearly equal specs, FP and SP, they may be blended with the same base oils, but differ by 5-10 % in shares. Just for comparison:
Specific LL-04 5W-40: PETROLEUM), C20 50, HYDROTREATED NEUTRAL OIL-BASED * 50 NOACK = 8.20%
If to summurize: take whatever you feel comfortable with from this list, just reduce a little bit your OCI in winter time and change oil in November and March. As an option, you may consider Mobil 1 ESP 0w40. It is on DEXOS2 list too.
Correction: NOACK = 9.43% (and FP = 214C vs. 230C in PDS) are related to Motul X-clean 5W-40 and MSDS of which shows:
LUBRUCATED OILS (PETROLEUM), C20 50, HYDROTREATED NEUTRAL OIL-BASED * 50
It does not change the idea, but for fairness' sake it was necessary to clarify. BTW, MSDSs of X-clean 5W-40 and LL-04 5W-40 show the same stuff.
Thanks to oil-club.ru resource we may fill in some gaps in our knowledge about DEXOS2 oils:
Code:
GM Motul Motul Motul LiquiMoly
Dexos2 Dexos2 X-clean LL-04 4600/4200
5w30 5w30 5W-40 5W-40 5w30
Visc. @40,°C 65.65 68.11 86.43 86.04 67.27/69.36
Visc.@100,°C 11.61 11.74 13.84 13.83 11.40/11.93
Visc. index 173 169 164 165 171 / 170
K.visc.(CCS) @–30°C, cP 5791 6304 - - 6209 /5806
FP,°C 230 232 214 220 229 / 232
PP,°C -38 -38 - - -34 / -38
TBN 7.04 7.23 5.99* 5.98* 7.14/6.28
Ash, % 0.83 0.80 - - 0.79/0.76
NOACK - - 9.43 8.20 -
Calcium 1951 2166 1909 1896 2188/1504
Magnesium 8 6 6 6 7/ 5
Boron 1 2 71 70 7/ 3
Zinc 889 1057 998 996 1034/862
Phosphorus 830 973 813 811 933/796
*TBN is measured as per ASTM D4739 that gives value about 15% less than ASTM-D2896.
Liqui Moly Top Tec 4600
Liqui Moly Top Tec 4200
Motul Specific Dexos2
Motul X-clean 5w30
Motul X-clean 5W-40
Motul Specific LL-04
Liqui Moly Top Tec 4200 was added just to show how may be different oils with partly identical specs/approvals (both meet ACEA A3/B4/C3, MB-Freigabe 229.51, BMW Longlife-04, but one also meets VW 504 00/507 00 and Porsche C30, but another meets DEXOS2,VW 502 00/505 00/505 01 and Ford WSS-M2C 917-A). Same with Motul Specific LL-04.
Thanks everyone for help
Ordered 3x4l Fuchs Pro Flex.
