Best chemical flush?
los angeles
Hi All.
I have a Toyota Land Cruiser with a 6 cylinder Turbo Diesel, and it's been a bit neglected in the coolant department. I wish to do a nice chemical flush on the system before I change the coolant. I've read some of the posts on this forum about that, but I'd like to know some opinions about the best chemical out there that will do an effective job of cleaning out the system and not damage the cooling system components. The radiator is an aluminum/plastic type.
The truck has been good about not overheating until recently. On a couple of steep hill climbs, the temps climbed up a bit. I am pretty convinced the fan clutch is operating properly, and the thermostat is fine also. I'm pretty sure I have some moderate blocking in the radiator.
So I'm looking for a chemical solution to this before I take the more drastic step of radiator replacement.
thanks for any help/suggestions
Surprised you do not have an answer yet. Basically the flush solutions are acid. The basic Prestone flush is citric acid. I do not think there is anything special about the flush chemicals. However, you Landcruiser must have a huge cooling system capacity so it might take more flush chemical than a regular engine.
The most important thing is to only use distilled water upon refill.
