Originally Posted by ChrisD46
hopefully removing brake fluid from the master cylinder then refilling with fresh fluid does make it down the brake lines to refresh the old fluid in the lines ?
Theoretically, when you step on the brake you are moving a column of fluid through the lines, and when you take your foot off, the column of fluid goes back the other direction. Maybe 1/4 or 1/2 inch in each direction. That the new fluid in the reservoir will mix with old fluid all the way back at the rear is anybody's guess. Maybe, maybe only after a year or two.
