Best ATF for a 2004 Chevy Impala SS
Oconomowoc Wi
What do you guys think would be the best ATF to use? My son has an 03 Monte Carlo SS that also needs changing...
I am thinking Maxlife, Mobil 1...
There is none better than Amsoil ATF period. Expensive yes, PIA to get, yes, worth it, yes.
What kind of a fluid change are you planning on doing. Cooling line flush?
The worst would be going to a shop and having them use some generic stuff where they add some additives to make it good for your vehicle.
I did a Vac suction drain and fill (6 quarts) about 3 months ago and will be doing a pan drop/new filter in a few days. Thanks.
I support this post 100%
Amsoil Synthetic or Red Line D4 ATF, all others are subpar.
I have used Mobil 1 ATF since they started making the stuff in the early 90s. I have never had a transmission fail(or PS pump for that matter) using Mobil 1 ATF.
