Originally Posted By: fdcg27
It depends upon the engine, and it depends upon how it is used.
BMW, VW and Mercedes did not come up with their own oil specs just for grins, for example.
Another example is GM, which has two North American specs, in addition to its Euro specs, in addition to SM.
API SM is not sufficient for every engine sold in this country.
Now, if you drive a typical car in typical conditions, any API SM oil will do just fine.
If you drive a beast that is more demanding, API SM is not a sufficient spec.
The best API SM oils meet demanding manufacturer's specs, while the lesser SM oils don't.
I have a bad habit of stating "API" when what I should be stating, to convey the meaning that is meant, is the oil that meets the spec as required by the OEM.
My particular dinosaur only needs SJ, though I still stick to SM oils. I'm also fussy about them and am willing to tinker a bit to try and improve upon whatever I'm using (simply because I believe oils are generally blended to deliver the best they can at a given price point, rather than being blended to be the objectively best product the manufacturer can produce - after all, all oil producers are profit driven and the profit motive and "best possible product" are not necessarily synonymous).
I'm realistic enough to know that any improvement, either by choosing one SM oil over another, or even if (successfully) improving it slightly, its still only somewhat better than another product, and the "better" is for my application of it and may not be any better for someone else's needs.
-Spyder
