I miss the Neon's, they were solid cars, keep it alive and running for many years to come.An stp that I picked up for my neon seals like a glove and wasn't expensive.
Other than having really weird issues with it hopefully. Apparently they ALL have idle air control valve failures, and the shift solenoid goes bad (mine has) and is now still a $300 part to replace.I miss the Neon's, they were solid cars, keep it alive and running for many years to come.
The solenoid pack on top of the transmission is a common failure point, unfortunately many condemn the transmission and many of these cars were junked for no real reason, you can purchase a solenoid pack on RockAuto just thoroughly clean the area prior to removal.Other than having really weird issues with it hopefully. Apparently they ALL have idle air control valve failures, and the shift solenoid goes bad (mine has) and is now still a $300 part to replace.
