- Messages
- 3,416
- Location
- Parts Unknown
![[Linked Image from pennlive.com]](https://www.pennlive.com/resizer/XjJZCopD6SqGkWKcAve1Mn8mqos=/1280x0/smart/advancelocal-adapter-image-uploads.s3.amazonaws.com/image.pennlive.com/home/penn-media/width2048/img/life/photo/potholes.jpg)
Tire selection can help prevent wheel bending to a point. This may seem odd, but stronger sidewalls can help prevent wheels from becoming bent.
A tire such as the Bridgestone Potenza RE980AS has a THREE ply sidewall. Very, very few passenger car tires have 3 ply sidewalls. Most have 1, some have 2. The impact on a 3 ply sidewall gets spread over a wider area of the tire lessening the impact shock from going straight to the alloy wheel which can bend it.
Same thing here til I got 17/18 inch rims. Had a few cracked rims with the 18 and just a couple bent ones with the 17. The 18 had 40's series and the 17 had 45 series. Prior to that had 60 series and up and never had a bent rim.Never had an issue with Aluminum wheels bending or being a wear item even with my old Honda that lived in Buffalo, NY and Kew Gardens, NY most it’s life. Minimum sidewall I’ve run has been 65. Sounds like narrow sidewall thing claims another victim.
A little tricky to do as the other problem with low profile tires is that the sport suspension these days don't give you a lot of room. Plus you run into the problem of the tire shop not wanting to mount tires that aren't the correct size for the car.If you have low profile tires and have bad roads. when you get new tires adjust the size to get more sidewall. Go up profile from 50/55 60/65 and so on. the extra inch or so you can fit will definitely help the wheels.
If you compare specs online what you'll find is that the sidewall/treadwidth ratios are not dramatic so going up one profile still fits inside the fender. Typically trading ~1 inch larger Diameter for <1 inch narrower width or so. Never had a problem i go in and tell them what size to put on and they do it.Same thing here til I got 17/18 inch rims. Had a few cracked rims with the 18 and just a couple bent ones with the 17. The 18 had 40's series and the 17 had 45 series. Prior to that had 60 series and up and never had a bent rim.
