So I had my tires rotated today and the tech says that the RF wheel (now RR) is slightly bent. These are the stock 19" wheels with the 225/45R19 tires that came on the car. The obvious thing to do it replace the wheel.
There is not a lot of tread left on the tires, so I'll probably be replacing them pretty soon.
I am thinking that since the bend in the rim is not too extreme (tech saw it when spinning - didn't notice it driving/steering when it was on front) and the wheel is now on the back, I will just drive it until it is time to replace the tires.
Any reason not to do this? Should be safe, right? Odd tread wear won't matter, as tires will be replaced anyway.
This got me thinking. I've never bent a rim before, and I've been careful with these 19's. There was one pothole... Also these tires are expensive!
So here's a thought: when it is time for new tires, replace the 19" wheels with 17's. Tires will be cheaper, less chance of bent rims, more "comfortable" ride, but "worse" handling (?).
I am probably over-thinking this and should just buy the [censored] wheel, but... thoughts?
Replace the damaged wheel or do the full swap?
