What about misting water into the throttle body as I rev it a tad from a spray bottle.... or even better ATF heck that stuff has some freaky detergent properties, not sure if it would cause any gunk buildup when burned in a motor or if it would just clean the heck out of it. Also would the best way to tell if it has worked be to check a certain plug before and after or is there a better way?
