Also, looking at the TopDon unit, it has the same exact display font/text as the Ancel! I bet it's the same exact electronics inside, this will be interesting to see the results.
I emailed Moto power early this morning, they are actually located in Lewes Delaware, I'm in Dover Delaware, they never contacted me back. I called Topdon excellent customer service. He explained to me, that the AB101 and the 100w is the same tester, except the 100w is Bluetooth capable, otherwise it offers the same features.. So I ordered the AB101. And I will post the results..Be interesting to see the results.. When you do test this time, can you include the resistance number that is included in the test results? See if those all measure the same..
If you look on Amazon, a lot of them do.. LMAOAlso, looking at the TopDon unit, it has the same exact display font/text as the Ancel! I bet it's the same exact electronics inside, this will be interesting to see the results.
Yup.. that's the chinese for ya, one company makes it, others slap their name on it. Here you buy the ancel but now it's turned into a major research/testing project.. Why do you get to have all the fun?! lolIf you look on Amazon, a lot of them do.. LMAO![]()
that's good to know about their customer service.. moto can't even be bothered to email ya back!? ya I can see why you bought the Topdon..I emailed Moto power early this morning, they are actually located in Lewes Delaware, I'm in Dover Delaware, they never contacted me back. I called Topdon excellent customer service. He explained to me, that the AB101 and the 100w is the same tester, except the 100w is Bluetooth capable, otherwise it offers the same features.. So I ordered the AB101. And I will post the results..
@Donald MotoPower is supposedly located in your neck of the woods..
LMAOWhy do you get to have all the fun?! lol
This is a pretty interesting video, the Ancel is fast, very nice as well..
Lewes DE is almost all tourist stores and shops. And Beebe hospital. Did not know there was a place selling battery testers.I emailed Moto power early this morning, they are actually located in Lewes Delaware, I'm in Dover Delaware, they never contacted me back. I called Topdon excellent customer service. He explained to me, that the AB101 and the 100w is the same tester, except the 100w is Bluetooth capable, otherwise it offers the same features.. So I ordered the AB101. And I will post the results..
LOL they're probably using Lewes Delaware as the US address, they're actually probably located in China..![]()
dang that's some good results, 3.32mOhms.. wow that's really low, most of the batteries I've had are around 4.3mOhms. and 904CCA, yup see? It's still testing above the rated amps, like most of the new ones lately. What was the resistance testing on the Ancel you have? I bet it was a slightly higher reading which would result in a higher CCA calculation. Which one are you going to keep? Or just order another Ancel and compare results?@researcher here are the results, first of all, the TopDon I was not impressed with the screen clarity, the cords were shorter, felt very cheap, but anyway here are the results..
That's from the Ancel & the TopDon, the Ancel readings, are the first 2 pictures, what I'm going to do, is return the TopDon and order another Ancel I believe.. The TopDon I know it's definitely being returned, that was packed up right after I used it..dang that's some good results, 3.32mOhms.. wow that's really low, most of the batteries I've had are around 4.3mOhms. and 904CCA, yup see? It's still testing above the rated amps, like most of the new ones lately. What was the resistance testing on the Ancel you have? I bet it was a slightly higher reading which would result in a higher CCA calculation. Which one are you going to keep? Or just order another Ancel and compare results?
Thanks for the update!!
ok I missed that part, thanks for clearing that up (pictures). Looking again at the pictures..after some rest, the results are very close between the two. Have you been able to verify that voltages with a separate multimeter? Either way I bet the next ancel is the same result as the first. How would I know this? When I tested my friend's ancel it was identical to mine. At least now you know the TopDon unit was really cheap quality.That's from the Ancel & the TopDon, the Ancel readings, are the first 2 pictures, what I'm going to do, is return the TopDon and order another Ancel I believe.. The TopDon I know it's definitely being returned, that was packed up right after I used it..
I didn't know the model I had but yes, that's it! No complaints. I basically do a load test so I know what condition my battery is in.Many on here have the Ancel BA101.
It's a battery in my Ford Edge, it's about 2 years old, my BMS light is on, that will come on, when the battery is under 40% of a charge. I am replacing the battery this weekend, I was going to do it today, but we got a little bit of snow that rolled in, so I'll probably just wait till tomorrow.. The battery is about 2 years old the brand name on it is Precision, it was manufactured by Stryten battery company if I am not mistaken.. it is a group 65 series. I will probably be going to Walmart tomorrow and picking up an EverStart Max. Which is the same thing as a Deka Gold.. I contacted East Pennok I missed that part, thanks for clearing that up (pictures). Looking again at the pictures..after some rest, the results are very close between the two. Have you been able to verify that voltages with a separate multimeter? Either way I bet the next ancel is the same result as the first. How would I know this? When I tested my friend's ancel it was identical to mine. At least now you know the TopDon unit was really cheap quality.
I gotta say again that I'm really impressed with this battery you're testing, that's some really low resistance!! Maybe I missed it, what battery is it that you're testing? How old is it?
that's just insane, that low of a resistance and it's still dying.. I've heard that the newer cars never fully charge the battery and they die early deaths. Something about trying to save fuel, stupid if you ask me. I can see why people put the newer car's batteries on battery tenders to charge them up!It's a battery in my Ford Edge, it's about 2 years old, my BMS light is on, that will come on, when the battery is under 40% of a charge. I am replacing the battery this weekend, I was going to do it today, but we got a little bit of snow that rolled in, so I'll probably just wait till tomorrow.. The battery is about 2 years old the brand name on it is Precision, it was manufactured by Stryten battery company if I am not mistaken.. it is a group 65 series. I will probably be going to Walmart tomorrow and picking up an EverStart Max. Which is the same thing as a Deka Gold.. I contacted East PennSame battery different sticker.. same thing for Napa and Sam's club!! Just some of them offer different warranties..
thanks for the update about the batteries... about your battery, ever think of getting a battery tender and charging up the battery from time to time? That way you'd save money in the long run with a battery that wouldn't be undercharged for a long period of time resulting in replacement every 2 years.. be cheaper to charge it up instead of buying expensive batteries.. just a thought.What I understand they manufacture Continental batteries.. that's exactly what's happening.. the alternator, stops charging let's the battery do the work, then starts charging again.. and that's why I end up replacing my battery every 2 years.. and it's pretty much like clockwork... And since I don't drive a whole lot.. . Probably doesn't help.
