Originally Posted By: 440Magnum
I wouldn't spend a nickel on "gold plated" battery terminals.
I have replaced terminals when they become corroded, but I will only use those clamp-on replacement terminals in an emergency. When the terminal gets too corroded, I replace the whole cable. Not very easy, but clamp-on terminals have 2 points of possible failure instead of just 1.
+1, corrosion gets in and on every one of the hundreds of copper strands, then travels down inside the insulation wrecking the cable. If I did have to use under duress one I'd throw a huge glob of solder over everything, or carry a crescent wrench along forever to fix the inevitable.
Sure gold is a great conductor. Lead is a mediocre one. One is not adding very much to "the system" with that piece.
