I have a Motorcraft Tested Tough Plus on my Montero, which was installed in July 2009. Had no problems with it, and it's been working perfectly.
The other day, I noticed the top of the battery was wet, so I cleaned it up, removed the tab on top and added a bit of distilled water, since it appeared to be a bit on the low side. The cranking sounded a bit weak afterwards, but it worked alright.
The car sat for about 3 days and this morning, it did not crank. I jump started it, and it is holding a charge but it only registers 10.7V on my multimeter with the engine not running. A load test drops that down to 9.5V. With all the accessories on, my multimeter registers 13.8V at idle. I did also notice some water coming out of the vents and the top of the battery is wet again, so I reckon I unnecessarily added the distilled water. Having said that, when I kill the ignition with the door open, the dome lights immediately dim.
Would I be able to still use this battery if I remove the excess water with a turkey blaster and put it on charge for a couple of hours, or is this battery toast?
Thanks!
