The battery has been disconnected for around 11 hrs now:
13.13 VDC
13.13 VDC
AT 13.13V I bet you still have some surface charge.
With my Fluke 117 I measured parasitic current.
Initial: 300mA
3 min: 20-80mA fluctuating
Hmmmmmm
At first it read 0.000A. Fuse was somehow blown. Luckily I had a spare.
The parasitic current on my 2005 Subaru fluctuates from 44-58mA, in synchronicity with the flashing security light on my dash.
If the covers are under stickers it is a 'maintenance free' battery and unlikely to be low on water, as their gassing voltage is higher.
Maintenance free flooded are unlikely to ever need rewatering before they die form age/sulfation in non cyclic usage, and are not a good battery if deep cycle duty is intended.
I have a 8 year old sulfated Exide Edge AGM battery that I recently removed from service. I charged it yesterday with a CTEK.
Today I gave it a 400A load for 15 seconds. 2 hours later it measured 12.95V at a battery temperature of 22degF.
Battery voltage can sometimes be misleading.
I can't think of any, as long as you give it good powered-up and powered-down times. Eg not just a second here and there. Make your ammeter connection as sturdy as possible.Is there any problem with doing multiple parasitic drain tests? I mean repeatedly connecting and disconnecting the battery?
Huh. Our CRV has a bad CD changer (supposedly, never tried it, don't have a reason to), and it won't hold a charge for more than a few days. Been looking for a reason to yank it, maybe it's time... Good article. I don't work on cars but have debugged a few things, and boy can it be one long list of things to check...'Bright Idea' For Short Detection | MOTOR
In this article I describe two parasitic drain case studies—one of my first, from more than 40 years ago, and my most recent. A technician’s nightmare is diagnosing an intermittent high parasitic drain, as were both of these cases. Neither study involves hybrid or electric vehicles. By parasitic...www.motor.com
www.crutchfield.comHuh. Our CRV has a bad CD changer (supposedly, never tried it, don't have a reason to), and it won't hold a charge for more than a few days. Been looking for a reason to yank it, maybe it's time... Good article. I don't work on cars but have debugged a few things, and boy can it be one long list of things to check...
I'm planning on Wallyworld's finest. Just need FM, Bluetooth and aux input.
