Wonder what you guys think. I have an 07' 4cyl Subaru with the original batter in it, and noticed it cranked slow when cold last winter. Don't use the car that often, maybe once a week, and only have 15K mi on it. Have 5W30 Quaker State Ultimate Durability oil in it. Thought the battery was probably the min size or getting old being 5 yrs old, but batts have less power in the cold, and then sitting so long might be the reason. When the battery goes I was going to get a bigger one. Back in the day I had a 4cyl Mercury Capri, and a friend with a Caddy convertible had to junk the car so I bought his batt, and it was the biggest Sears Die Hard. I had an alternator go, and had to get one from out of state, so ran the car without one for a few mo. I used to check the capacity with a hydrometer, and could crank the car when the float was at the bottom.
Wondering how long a battery will last with limited use? Does that matter? Wonder if it could last much longer than the rating? Wonder about the timing belt also. Supposed to be good for 9yrs/105K mi I believe, but don't want it to break. Subaru changed to a timing chain which I would have preferred, OR a Non interference engine so the valves Couldn't hit the pistons if the belt broke. One car with an interference engine had a Tripple Chain.
