Quote:
BTW, a good whack with your heavy hammer right on the stud will usually pop it out.
Agreed. I'm no fan of pickle-forks, personally- and I rarely find them necessary. They generally destroy the boot, and those aren't really replaceable on lots of suspension components.
I find that a well-placed whack with a hammer will free most taper fits. You just whack the piece that the taper fits into, and it'll often just fall out. An assortment of heavy drifts helps with this method. And when it isn't possible to hit solidly on the piece that the taper fits into, it often works well enough to loosen the ball-joint nut and hit the nut with a hammer.
Now, all this advice should be taken with a grain of salt seeings how most of my experience in these matters is on heavy trucks, tractors, and the like. But the same methods have always worked fine for me in automotive applications too.
