Baldwin post micron ratings now
VA
I guess Baldwin got tired of answering micron questions. I was crossing a filter on their site and noticed that under the filter specs, absolute and nominal micron rating is listed now. Pretty cool and wish more companies did this.
What kind of micron sizes are they showing with those nominal and absolute efficiency ratings?
If you look by application no micron info. If you cross reference, it shows it. AC Delco PF64 to Baldwin B7422, 9.8 Nominal; 27 Absolute.
Below is a link to the oil filter I would use on my Subaru and I am not seeing the information you are referring to:
https://www.baldwinfilters.com/port...lication=Automotive & Motorcycle Applications
Also what is the exact difference in the definition of absolute and nominal ratings?
Does absolute = 99%
Does nominal = 50%
Even though I don't use them, that's too bad about answering inquiries. CS used to be fairly responsive. 'In my observation' while they have the appearance of a well made filter, not especially noted for high efficiency.
As for using the terms nominal and absolute to rate, especially when it comes to 'nominal', not my preference. Generally speaking, nominal is taken to be at 50% but that's not written in stone. A google search including this site will confirm that. I started a thread here on that topic years ago and may show up in search.
As for absolute 'I think' being precise it's at 98.7%.
If I was being picky about knowing efficiency rating , having the percent with the micron level with ISO 4548-12 , first choice.
But the terms are better than no rating at all.
Try crossing a known filter number in the cross reference section and see if that helps.
I cross referenced the Wix 57055 and got Micron Rating: 23 Nominal; 45 Absolute. So that reflects what the efficiency of the corresponding Baldwin filter is?
The Wix 57055 is 99% at 23 microns so no I am very confused unless they are referring to the Wix XP which is likely closer to those numbers based on what I have seen elsewhere.
My B7449 at Baldwin site
That’s excellent efficiency. Good to get the updated info. on Baldwins. Thanks.
I wouldn't call 98.7% @ 27u excellent efficiency - what is it at 20u ? ... maybe 85~90%. But it's definitely better than say 50% @ 20u.
Most places in the filter industry define "absolute efficiency" at 98.7 % (and sometimes round it to 99%) and "nominal efficiency" at 50%.
There is no difference in 98.7, 99, or 99+ Imo, because at those levels statistics go to pot from the lack of particles, empty data, experimental error. 99 is merely rounding 98.7, and Fram says 99+ which is extrapolating from the graph, and rounding off. One big happy make it go higher party to fool the people on the box. Then the people say o ahhh and buy the filter when it really is all marketing fluff.. But the goal of filter in Walmart’s check out line has been fulfilled. That’s competition for you. 😄
You left out the particle size in your tome.
Go read ISO 4548-12 sometime and you'll then understand why it can be rounded up. Just more of you're biased misinformed trolling without leaning much of anything, lol.
Guess Fram could say 98.7% efficient at 18 microns, but would rather stick with the efficiency at 20u since that seems to be kind of an industry standard target particle size to express efficiency.
Yes and the companies that avoid that Gold Standard aren't doing so because they are honest!
Yes and the companies that avoid that Gold Standard aren't doing so because the are honest!
Bingo ... these companies cross-check each other (the big filter companies have their own ISO testing labs), just waiting to send a letter saying stop false advertising.
