After putting off and looking at place and ideas on where to put my Baldwin B50 filter, I finally have it installed on the car now.
I bought one of those blue anodized sandwich adapters with the 4 port 1/8 NPT plugs and used one of them with a 90 degree elbow and a 1/8 NPT x 1/4" barb and some 1/4" fuel injector line. The return is simply into the drilled hole in the oil fill cap. BOY was I surprised at how much oil really flows out that hose at an idle!
After looking at the small restrictor orifice on the B50 Baldwin filter, I was expecting something of a trickle. Wonder what the flow is? Looks like I could fill a gallon jug in a minute or two.
Which brings me to ask on here... How well do the barb hose end hold with hose clamps? I would think that if the hose popped off, either at the sandwich connector or the inlet at the filter mount, I could loose oil at an alarming rate. I don't think the oil return line after the filter is such an issue, as there is really nil for pressure of the oil going to a zero pressure return point.
I'll have to take pics soon!
