It has two piece rear main, and yes on these motors the sending unit sprays a lot of oil when it fails. A buddy of mine had this happen while on the highway and lost 1qt/hr. Either way I've already ruled that out, and the filter, and the valve cover. sorry for the lack of info, i have a very busy schedule. I let it idle today after work and let it warm. it was dripping slowly, so i gave it some rpm's and watched the filter and the sending unit, nothing. Then once the oil was warm, I'm assuming, it started pouring even at idle, coming from the transmission bell housing. So unless there is a plug of some sort back there that has failed it has to be the rear main or the pan gasket. II really don't think its the pan gasket b/c I was very careful installing this one, and followed the instructions on applying some RTV on the front and the rear of the gasket. I have replaced manny gaskets and never had a problem. And I highly doubt it was over torqued as it has crush washers to prevent this. But I can always pull out the torque wrench and see bouts what they are at. My only thought is the rear main has trapped some dirt in it, or there is a grove worn into the crank that had gunk sealing it and the ARX cleaned that....
