I believe My 05 Honda Civic may have a bad head gasket or cracked/warped head or block because it has been overheated due to low coolant, bubbles, bad hoses, cooling fans not coming on, etc. The car was immediately pulled over and turned off to prevent damage. The scary part is that the coolant pressurizes to slightly higher than normal levels and the pressure does not go away even once it completely cools down for 24 hours. It still sprays coolant when I take the cap off and hoses are still hard. This is new since the last overheat. I do not know if it has a bad hose causing air to enter or what. No steam from under the bonnet or out the exhaust. No oil in radiator or coolant in oil. No blow by into oil. What do you guys think about this?
