B58TU Oil Choices
Hey everyone,
I just picked up a 2020 M340i a few weeks back and would like to do the first oil change on it this weekend.
I’ve been searching the forums and am seeing conflicting recommendations for the oil type I should buy.
The manual recommends 0w20 or 0w30 LL-FE17+ oil, however some people on the forums are saying to use LL01 5w40 - so I’m a bit confused. Was planning to use Pennzoil platinum euro 5w40, but won’t if there’s a better option.
I own the car and plan to keep it long term. I live in Southern California. The car is stock and is mainly used for a short city drive commute and spirited weekend drives. My OCI will be 5k. 43k on the odometer currently.
Can someone recommend a good quality oil to use in my B58TU?
Any help is greatly appreciated.
Pennzoil Platinum Euro L 5w30 is LL-04. I would strongly consider that oil as well. It gives the benefits of higher viscosity and BMW approval in a lower SAPS oil.
Assuming you car does not have GPF, then the LL-01 oils should be ok to use as well.
If you want to stick with your manual recommendations strictly (LL01FE is the 0W-30):
BMW TPT 0w30 or Motul Specific LL01FE 0W-30
I would personally deviate slightly and use Mobil 1 Full Synthetic 0w40.
