Hi all,
I have a 2001.5 Audi S4 with 160,000 miles, it has been tuned to run at 24 lbs of boost and was dyno'd at 442 AWHP and 460 AWTQ. My question is this: Currently I use Rotella T6 5W40 synthetic oil every 5,000 miles, but my oil temperatures have been getting a bit high (for my comfort), considering that during the winter (if it can be called that in south Texas) it was regularly running between 180-200 degrees. However, recently it has been climbing into the 230-250 degree range which has been causing me some concern. Is 5W40 an appropriate viscosity for an entire summer of 100+ degree days? I realize that a stock S4 would probably be OK, but mine isn't quite stock. I was considering going to Castrol Edge synthetic with my next change, but I didn't know if I should stick with the 5W40 or go with something like a 0W60 like what is used in the E60 M5. Thanks!
