This small 208 cc engine will back fire once when I turn off the ignition switch. It does it all the time. Other than that is runs fine. For winter storage I completely drain the gas and remove the pump and bring it inside
Original when I purchased it 2 years ago I adjusted the valve lash, . the code on this engine is 13U2-80098013 made in China engine. the B&S web site does not list this engine but I found a service manual for a 13U200 which looks identical.
Both intake and exhaust were at .10 mm and as per page below I set both at .15 MM. This made the engine easier to start but I am wondering if that`s the cause of the back fire and thus I should re-adjust them back to .10 mm ?
