So I got this Mountaineer last month with 110,000 miles on it. Last week I had the shop do a transmission filter and then complete fluid exchange as well as replace the transfer case fluid. The previous ATF looked good they said, but the transfer case fluid looked nasty. Now both are filled with Redline D4 ATF. I plan to leave the transmission alone for 50,000 or more miles and then have the same done again. But the transfer case, it seems to me, needs more attention. Given that the existing fluid was nasty, I suspect the Redline will do some cleaning and it may be wise after maybe 5000 miles to drain and refill it. What do you think?
