Avalanche front and rear diff change.
North Carolina
Going to change the diff oil , looking at amsoil severe gear 75w90 for both the front and rear. G80 rear, apparently i don't need Ls additive.
My local AA carries valvoline syn autotrak fluid for the transfer case.
Any suggestions? Anything i should use other than above?
Thanks.
EDIT: No where can i find how much each diff takes, so i don't know how much to buy. Anyone guess how much i need?
Thanks.
In my silverado ive done two changes. First at 25k with valvoline synpower 75w90 front and rear. Second at 65k with castrol syntex 75w90 front and rear.
I change my diffs every 40-50k. Transfer case once per year.
My 2005 Avalanche with the G80 calls for 2.1 qts. I would add 2 qts and check with the pinkie. You want it a little below the fill hole. My Avalanche is a two wheel drive, can’ t help you with the front. P.S. You need to drive yours more! Mine just rolled over 194,000 miles.
Any 75w90 will work. You may want to get 5 qts (a little more than 2qts for both front and rear). And I would go to the dealer for transfer case fluid,they will give you the correct fluid ad amount
Donnyj08, how much did it take? how much do i need for each diff?
Thanks.
Get 3 for the rear and 2 for the front. The rear will take 2.4 or so. The front about 1.7 in my experience.
That will leave you with extra.
