Originally Posted By: DoubleWasp
Originally Posted By: stchman
Filters on automatic transmissions are essentially a waste. Since an automatic transmission is a closed system, the inside stays clean. Automatic transmissions don't burn fuel or suck in large amounts of air so external contaminants are not being introduced. An automatic transmission's worst enemy is heat, keep the fluid cool and change it per manufacturer's recommendation.
The system is capable of building up solid contaminants from the clutches. Changing the fluid actually increases these contaminants significantly, which is why a fluid change is the perfect time to install a filter.
For the third time, there is an external filter! http://www.mdxers.org/forums/73-first-ge...r-pictures.html
