1995 civic dx with the 4 sp auto.
I changed the fluid recently, by doing a double drain and fill. Drain, fill, run the engine through the gears for a few mins, drain, fill. The transmission started to do a whine around 3000-4000 rpm, whether in P, N, or in gear (I'm saying it's related to revs , not speed or gear).
Shifting is awesome, and this noise happened with honda atf z1, and also chevron atf dex3 (I replaced the fluid again with double drain and fill using that).
It goes away, and comes back, so randomly that I get confused. Also, it happens in the morning, but this morn I just shut off the engine, waited 5 secs and turned it on and it went away. So, I don't think its from cold fluid.
It's strange, and the same noise has happened when I put auto rx in my trans, which worried me, so I drained and filled twice, and it was fine after that. Hopefully the screen isn't clogged and maybe that makes the pump make the noise? Maybe I should run lube control or autorx and leave it in gear sitting for 30 mins to move the fluid around?
Or, maybe there's air caught in the trans? If so, how would I get that out?
Thanks,
Robert
[ January 19, 2004, 02:51 AM: Message edited by: robnitro ]
Thanks,
Robert
