Guys,
I didn't know where to post this. This seemed to be the most applicable.
When you run external filtration setup for your automatic transmission do you get rid of the internal filter (and I mean pull the filter out and keep the sump, otherwise you wouldn't be able to pull fluid from the pan) or do you use it in addition to the internal filter? Does that make sense? Is there any manufacturers that make a filter less filter to do this?
I'm fine with leaving the sump and filter intact but I like the idea of removing the filter and putting an external one on. That way I can change it anytime and change the fluid without ever having to drop the pan again.
What would be the micron rating on the stock filter?
What would I need to get to at least equal what the stock unit would do?
Would I need to get a hydraulic filter instead of an oil filter since the fact that transmission fluid is a hydraulic fluid and not oil?
Matt
Matt
