I've had lots of cars, most with manual transmissions. I am a little uncomfortable with auto transmissions, and like to decide the proper gear instead of a gear being chosen for me. I don't like to drive manual transmissions in stop and go traffic though.
When I stop at a stop light and know I will be stoped for over about 15 seconds, I usually shift an auto transmission into neutral during the stop. I don't like the feeling of the transmission pulling against the brakes and how hard I have to hold the brakes if left in gear.
Good idea or not? I know it cycles the u-joints, but all slop in the driveline should be taken out if I shift into neutral after I stop. Might save a drop or two of gas but also might slightly wear the clutches, but probably less than a normal shift would.
