Yea-the non truck owners say it's too warm-us truck owners know it's normal. Just another day on BITOG.Welcome to 2021. 200F cap was probably true several decades ago.
My ZF8 runs ~ 200f in normal city driving.
Not yet. Yesterday was the first time I drove it.You say the tuck is nearly new, 1162 miles. Did you check the fluid level?
I didn't mess with any of that. Dunno if it even has a switch for it.if you don't keep the torque convertor locked up it will generate heat. My 2012 Ram I manually shift it if I'm towing to keep my TC locked up. You keep the TC locked up by turning higher RPM's. When the RPM's drop the TC becomes unlocked to save the drivetrain. If you keep the TC locked it will drastically reduce your transmission temperatures. On my Ram I usually see 60 to 80F over ambient. So to hit 200F It would need to 120F outside...
just my $0.02
There's always a chance the fluid level is a little low, even in a new vehicle. It's certainly worth a look.Not yet. Yesterday was the first time I drove it.
I see the same on my Silverado in normal usage.if you don't keep the torque convertor locked up it will generate heat. My 2012 Ram I manually shift it if I'm towing to keep my TC locked up. You keep the TC locked up by turning higher RPM's. When the RPM's drop the TC becomes unlocked to save the drivetrain. If you keep the TC locked it will drastically reduce your transmission temperatures. On my Ram I usually see 60 to 80F over ambient. So to hit 200F It would need to 120F outside...
just my $0.02
Looking at your dash picture you should have a +/- switch on your shifter. If you operate in M instead of D it should help keep the torque converter locked. At least that’s how my Ram works.
Just my $0.02
Michael did you see the Sonnax part for the bypass valve yet ? Sonnax bypass valve eliminatorWelcome to 2021. 200F cap was probably true several decades ago.
Nope, this is news to me. Have you done one?Michael did you see the Sonnax part for the bypass valve yet ? Sonnax bypass valve eliminator
I'm curious as to whether that is just the talking point (however quantifiably true) and how much longevity takes a back seat?I was talking to a Ford powertrain engineer awhile back. Those transmission temps are as designed. It's all about efficiency
No the part just came out if I’m not mistakenNope, this is news to me. Have you done one?
I am under warranty until 125K so I let it be FCA's problem.
