On a Ford Taurus, if one was to drop the pan, change the filter, button things up and refill with new fluid, how long would it have to run in order to fully mix the new fluid with the old trapped fluid in that is in the torque convertor and cooler lines?
Curious as to whether a 2 or 4 minute run while on the lift is sufficient or whether the car actually has to be driven. Want to pull the mixed fluid out through the dipstick tube with a Vacula in order to further dilute the old with the new.
Also, does the torque converter drain to the input shaft when the pan is removed or stay fully loaded.
Thanks....
Thanks....
